TCP Lighting's 9W 2-ft LED T5 Tube, featuring a color temperature of 4100K, is an LED compatible replacement for linear fixtures that operate independently of ballasts. Shop our full selection of TCP Lighting's products at HomElectrical today!
Satco Lighting's 25 watt T5 tube light features single or double ended wiring, energy efficient LED lighting, and a natural light color temperature ideal for commercial applications. Shop HomElectrical for more LED tube lights today!
Euri lighting has created a shatterproof and easy to instal 4-ft long T8 bulb. The ET8-18W50SH will provide plenty of light with low energy wih its 2,600 lm output and 18W. Shop more LED lighting products at HomElectrical.com today!
Satco's 4-ft 25W LED T5 Tube offers a single or double ended wiring option for commercial lighting. This bulb provides 50,000 hours of daylight colored light by using energy saving LED technology. Search HomElectrical to find more LED T5 tubes!
Green Creative's 12W LED T5 Tubes provide easy to install, plug and play direct installation suitable for hassle-free installation and maintenance. These products are rated for 120V-277V installation. Shop HomElectrical for more LED T5 Tubes today!
Satco's 3-ft T5 Tube has a selectable color temperature and a white finish. It's rated for 120V-277V installation, has a G5 base and single or double-ended wiring. Need more T5 tubes? HomElectrical.com has a wide variety of tubes to choose from!
Satco Lighting's LED T5 Tube uses direct line voltage installations, not requiring ballasts or external drivers for installation and are durable against damage due to its shatterproof coating. Shop HomElectrical for more LED tube lights today!
Sylvania's 2-ft T5 tube light is a lightweight, energy saving replacement for traditional fluorescent lights. This tube features a soft white color temperature ideal for offices and retail spaces. Shop at HomElectrical for more LED tube lights today!
Sylvania's 3-ft T5 tube light is a lightweight, energy saving replacement for traditional fluorescent lights. This tube features a soft white color temperature ideal for offices and retail spaces. Shop at HomElectrical for more LED tube lights today!
Sylvania's 3-ft T5 tube light is a lightweight, energy saving replacement for traditional fluorescent lights. This tube features a neutral white color temperature ideal for offices and retail spaces. Shop at HomElectrical for more LED tube lights today!
Sylvania's 3-ft T5 tube light is a lightweight, energy saving replacement for traditional fluorescent lights. This tube features a cool, crisp color temperature ideal for offices and retail spaces. Shop at HomElectrical for more LED tube lights today!
Sylvania's 3-ft T5 tube light is a lightweight, energy saving replacement for traditional fluorescent lights. This tube features a natural light color temperature ideal for offices and retail spaces. Shop at HomElectrical for more LED tube lights today!
Sylvania's 4-ft tube light replaces inefficient fluorescent lighting with cost effective and energy saving LED lighting. This soft white tube is perfect for retail spaces and much more. Shop at HomElectrical for a wide variety of LED tube lights today!
Sylvania's 4-ft tube light replaces inefficient fluorescent lighting with cost effective and energy saving LED lighting. This neutral white tube is perfect for retail spaces and more. Shop at HomElectrical for a wide variety of LED tube lights today!
Sylvania's 4-ft T5 tube light replaces inefficient fluorescent lighting with cost effective and energy saving LED lighting. This cool, crisp tube is perfect for offices and much more. Shop at HomElectrical for a wide variety of LED tube lights today!
Sylvania's 4-ft tube light replaces inefficient fluorescent lighting with cost effective and energy saving LED lighting. This cool, crisp tube is perfect for offices and other work spaces. Shop at HomElectrical for more LED tube lights today!
LEDVance Sylvania's 2-ft 8W LEDlescent T5 Tube in 3000K replaces traditional fluorescent lamps by bypassing the existing ballast. Sylvania's T5 Tubes offer instant light and uniform light distribution. Shop more T8 tubes at HomElectrical now!
TCP'S 4100K T5 tubes are the perfect replacement for old fluorescent lighting. These tube feature multiple ballast compatibility and provide up to 50 percent, energy savings compared to fluorescent lighting. Shop HomElectrical for more!
Sylvania's 4-ft 24W LED T5 plug & play tube has a mini bi-pin base & is designed to replace a traditional fluorescent T5 tube. It is dimmable with compatible ballast & a 3000K color temperature. Explore more LED T8 tubes at HomElectrical.com today!
Sylvania's 4-ft 24W LED T5 plug & play tube has a mini bi-pin base & is designed to replace a traditional fluorescent T5 tube. It is dimmable with compatible ballast & a 3500K color temperature. Discover more LED T8 tubes at HomElectrical.com today!
Sylvania's 4-ft 24W LED T5 plug & play tube has a mini bi-pin base & is designed to replace a traditional fluorescent T5 tube. It is dimmable with compatible ballast & a 4100K color temperature. Check out more LED T8 tubes at HomElectrical.com today!
Sylvania's T5 tube light with 3000K color temperature is an energy saving and cost effective replacement for traditional fluorescent tube lights. These tubes are rated for 120V-277V installation. See more at HomElectrical for more LED tube lights today!
Sylvania's T5 tube light with 3500K color temperature is an energy saving and cost effective replacement for traditional fluorescent tube lights. These tubes are rated for 120V-277V installation. Shop at HomElectrical for more LED tube lights today!
Sylvania's T5 tube light with 4100K color temperature is an energy saving and cost effective replacement for traditional fluorescent tube lights. These tubes are rated for 120V-277V installation. View more at HomElectrical for more LED tube lights today!
Sylvania's 4-ft 24W LED T5 tube with direct wire installation has a 4100K color temperature giving off 3500 lumens with a minature bipin base. Shop more T5 tubes at HomElectrical.com today!
GCR's 14.5W 4 ft. T5 Tube has a color temperature of 3000K, 1800 lumens, 310 degree beam angle, and it is rated 120V-277V for installation. This product is easy to install and suitable for encolosed fixtures. Discover more LED T5 Tubes at HomElectrical!
GCR's 14.5W 4 ft. T5 Tube has a color temperature of 3500K, 1800 lumens, 310 degree beam angle, and it is rated 120V-277V for installation. This product is easy to install and suitable for encolosed fixtures. Explore more LED T5 Tubes at HomElectrical!
GCR's 14.5W 4 ft. T5 Tube has a color temperature of 4000K, 1800 lumens, 310 degree beam angle, and it is rated 120V-277V for installation. This product is easy to install and suitable for encolosed fixtures. Discover more LED T5 Tubes at HomElectrical!
GCR's 3 ft. 12WT5 Tube has a color temperature of 3500K, 1450 lumens, 160 degree beam angle, and it is rated 120V-277V for installation. This product is easy to install and suitable for encolosed fixtures. Discover more LED T5 Tubes at HomElectrical!
